Can you guess which cylinder is bad?
Posted: Sat Dec 11, 2010 11:31 pm
Ok, Which cylinder do you think is the one that was giving me problems?
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
http://trojanboatsforum.net/wforum/
Allen Sr wrote:How many hours are on it? Looks like oil control rings went bad? Is that 53 or 71 series? Could also be one other part gone bad with those series engines but it still requires tear down/overhaul.![]()
RWS wrote:repair = parts replacement.
More important - determine cause of failure.
So to us non-diesel guys who may be diesel guys some day and always want to learn as much as we can, what are we seeing in the photo that indicates the number 2 cylinder is bad?prowlersfish wrote:Allen Sr wrote:How many hours are on it? Looks like oil control rings went bad? Is that 53 or 71 series? Could also be one other part gone bad with those series engines but it still requires tear down/overhaul.![]()
71 series , ever seen a in line 6 53 series or a 92 for that mater ? Most likely broken rings . you can pull the air box and inspect the other clnders /rings . if low hours you can replace the jug and piston , if higher then do them all , and check the heads for cracks . and at least check the injector in #2
I knew '92 series were strictly V engines wasn't sure about the '53 series?prowlersfish wrote:Allen Sr wrote:How many hours are on it? Looks like oil control rings went bad? Is that 53 or 71 series? Could also be one other part gone bad with those series engines but it still requires tear down/overhaul.![]()
Allen Sr wrote:I knew '92 series were strictly V engines wasn't sure about the '53 series?prowlersfish wrote:Allen Sr wrote:How many hours are on it? Looks like oil control rings went bad? Is that 53 or 71 series? Could also be one other part gone bad with those series engines but it still requires tear down/overhaul.![]()
71 series , ever seen a in line 6 53 series or a 92 for that mater ? Most likely broken rings . you can pull the air box and inspect the other clnders /rings . if low hours you can replace the jug and piston , if higher then do them all , and check the heads for cracks . and at least check the injector in #2![]()
I always said I was never to old to learn. Thanks for the info Paul. Thats why your the King and I did vote for you!!prowlersfish wrote:Allen Sr wrote:I knew '92 series were strictly V engines wasn't sure about the '53 series?prowlersfish wrote:
The 53 series where made inline up to 4 cly the 6 cly and larger where V engines
