Port ignition starts starboard engine-
Posted: Thu Jun 24, 2010 10:05 am
I have had my 1979 F32 Trajan for 8 years with no problem. Yesterday working on the boat my helper tried starting the starboard engine but instead of hitting the normal start key (someone switched the key for a toggle switch) he hit the RED Emergency start key which sent port power to the starboard starter. Since then the port ignition key turns BOTH engines so if the starboard is running it tries starting it again screwing up my starter.
How to I reset or correct this problem? I remember when I first bought the boat I did try the emergency starter to see if it worked but never had this problem. Since then the wiring in the bilge was redone and a shut off switch added. Have never touched the emergency switch since then until now.
Please either email me at ajp1431@comcast.net or call on cell at 914-393-1377.
Again, if starboard engine running that starter motor grinds when you turn the port ignition key. If the on starboard switch is on and you turn the port ignition key both engines start. If the port is running there is no problem starting the starboard engine.
All this not a problem other than if the port engine stalls as it won't restart without jamming up the starboard starter motor.
I understand that the emergency start swith sends power from port to starboard but there must be a way to reset this.
PLEASE HELP
Andy
PLEASE HELP
Andy
