I'm replacing my helm lighting switches (engine rm, deck lights) with Carling Contoura's that have a built in indicator light.
The old switches are right next to each other and wired as follows:
all white wires tied together
12v black feed goes to SW #1 and then jumped to other two
ground to each switch
ea switch has two terminals
The new switches have three terminals. I can get them working (on/off) but can't get the indicator light functional. If I "jump" from the 12v term to the indicator light terminal, the light will only come on in the "off" position, not when turned "on". I tried reversing the other two terminals but it didn't make a difference.
They're wired the same as the old switches but I have the extra terminal. I called Carling and they said I shouldn't have to jump anything.
What am I missing?
thanks,
switch wiring - can someone tell me what I'm doing wrong?
Check out page 2 and 3. Does this help?
http://www.totalsource.com.au/pdfs/Swit ... 200907.pdf
Be sure you have the correct switch, normally closed or normally open.
davidsmith
wiring
If the old switch was a push pull or a toggle with no light then you only have positive wires connected to switch. You will need a negative wire for the light to function.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
Re: wiring
davidsmith wrote:If the old switch was a push pull or a toggle with no light then you only have positive wires connected to switch. You will need a negative wire for the light to function.
That is correct
thanks guys, that does help....
it looks like I need to run a ground wire to each of the #7 terminals to get the indicator light working.
I'll try that tonight!
