Headed out for test run
Posted: Sun Mar 07, 2010 2:25 pm
Wish Me luck guys I am off for 2 test run.. Ill post the results when I get back. Might try take some video.
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
http://trojanboatsforum.net/wforum/
LSP wrote:prop>?
No not yet on the prop. I do not have a replacement yet, I will look for one this week. When I took it out today, it ran good as expected. WOT was 3000rpm It took few to plain out, then I throttled back to around 2200 - 2400 rpm. I had to play with the trim tabs get it to plain. I did notice some vibration while it was @2400rpm. This very well could be from the prop. So I will locate one this week and try it again next weekend. While I was coming back in the alternator quit charging so that is another thing I will have to see why its not charging.turtlem1969 wrote:sure its not a screw?
Paul .... I thought that was the chrome things that Rodman just bought to make the boat go. hahahaha I didn't see your post until I sent mine. I was curious if he had changed his fan or not.....prowlersfish wrote:LSP wrote:prop>?
You know that thing under the boat that goes round and round and moves the boat . looks like a fan.
You guys are not going to let me live that one down are you?mr elevman wrote:its sits nice due to the added waight in the stern witch caused the bow to rise hears an idea take the train horns and mount them under the boat with a good compresser and you can have a jet drive to complament the over sized prop and remember not to use flairs to remove prop
I hope to find the right size prop I need.mr elevman wrote:not in this life time its all good man
