My boat has Perko 915 side lights. The bulb base and wire connectors were corroded beyond repair and neither light works. Replacing them, the whole fixture, is $75 a pair. Replacing the plastic base with the wiring and base is $35 for the pair.
This chrome case and the plastic base are fine. I just need the bulb base and connectors. Does anyone know if I can just replace those and what the part would be?
Thanks,
WW
Nav side lights
wet wonder
Nav side lights
1975 Trojan F-25 Express Hardtop
Mercruiser 351 233hp
12v system - Solar panels 170 watts
You can replace the bake-o-lite base with the two contacts and the spring from parts obtained from most any auto parts dealer. I have got them from a NAPA dealer. They cost about $3.50. I don't have the part # readily available but will get it and post it latter.
This also works for the overhead cabin lights light.
Gerry
1979 F36 Twin Chryler 440's
http://www.westmarine.com/webapp/wcs/st ... assNum=529
Or
http://www.westmarine.com/webapp/wcs/st ... assNum=296
Or
wet wonder
I am not sure of the number off hand but I belive it looks like the uper right hand bulb in the photo
http://www.westmarine.com/webapp/wcs/st ... ctId=25634
Most marine store have the sokits in stock so you can look at them to make sure they are correct . the number should be on the old bulb . perko has a part number but its not you normaL TYPE number . Jerrys numbers sound right .
I looked on my boat fot the # of the socket replacement parts, but didn't find it. The parts come with either a single or double contacts. Single is used in the cabin over head lights. Double is used with the running lights.gjrylands wrote:You can replace the bake-o-lite base with the two contacts and the spring from parts obtained from most any auto parts dealer. I have got them from a NAPA dealer. They cost about $3.50. I don't have the part # readily available but will get it and post it latter.
Gerry
