Hynautic steering
Posted: Sun Jul 05, 2020 10:31 am
by fourreins
I have a 1989 International and I believe I need to add fluid to the system. I see a small cylinder with a small pump to pressurize system at the back of the boat. The fluid can be seen through the site glass and is below minimum. How do you add fluid to this system? Thank you!
Re: Hynautic steering
Posted: Sun Jul 05, 2020 2:21 pm
Relieve the pressure like you would a tire then remove the cap(1" ?) that the air valve is on and fill there . A bike pump works well to pressurizer the system
Posted: Sun Jul 05, 2020 9:15 pm
by fourreins
So I can see how to relieve the pressure but don’t see any fill cap. Only think on the top is the small pump to add pressure????
Posted: Mon Jul 06, 2020 8:15 am
fourreins wrote: ↑Sun Jul 05, 2020 9:15 pm
I don't recall a pump on any hynautic . The fill plug is below the valve you relive pressure ad air , photo of your tank ? here's one a little different then mine fill is circled in green
Posted: Mon Jul 06, 2020 9:38 am
Did some checking the ones with the pump , you unscrew the pump to fill .
Posted: Mon Jul 06, 2020 9:21 pm
by fourreins
- Here is a photo of mine
- 462E9A29-36E7-4658-ABBD-2F1416184204.jpeg (91.65 KiB) Viewed 10001 times
Posted: Mon Jul 06, 2020 9:24 pm
by fourreins
I tried to unscrew the nut under the black pump and got nervous because it seemed real tight and I didn’t want to break it.
Posted: Tue Jul 07, 2020 6:20 am
That is the fill . But you could fill it where the gauge is , it would be a slow fill .
Posted: Tue Jul 07, 2020 7:39 am
by fourreins
Thank you for all your help. I’ll take another look next time I’m at the boat.
Posted: Sat Jul 11, 2020 10:49 am
by fourreins
Well I was able to unscrew the nut under the small black knob pump.... definitely the fill. Thank you!
Posted: Sat Jul 11, 2020 12:32 pm
Glad you got it . Thanks for the up date !
Posted: Tue Jul 14, 2020 3:06 pm
by kullphoon
I just had to have my helm pump rebuilt and in the process I was able to obtain hynautic manuals. This is the place I sent my pump and you can find a lot of useful information here.
http://www.boaterstore.com/hynautics/hynautic1.html
