International Express Water Tank Capacity
Posted: Sat Jul 27, 2019 6:27 am
by RWS
My 1983 Express features the built into the hull fresh water tank.
The only problem with this is when you are out on the hook, you never really know how much water remains in the tank, making you and your crew ultra conservative with eater usage.
Taking a holesaw to the tank top to add a float sensor was out, as I'd likely never remove all the fiberglass grindings.
I recently added an actual water meter to my fresh water tank.
I can confirm that on this 1983 International Express Cruiser the fresh water tank capacity is actually 52 gallons.
Re: International Express Water Tank Capacity
Posted: Sat Jul 27, 2019 8:01 am
What type of meter ? Photos of install ?
Posted: Mon Jul 29, 2019 5:49 am
by RWS
this photo is turned sideways, it's actually reading 52
purchased on Amazon.
Installed in the forward bilge located in the cabin
Moved stainless steel strainer upstream of meter
I will be mounting the digital readout up in the galley
meter $75
pulse counter $38
peace of mind on the hook = PRICELESS
Posted: Mon Jul 29, 2019 6:29 am
Pretty cool looks like the meter on my house .
Posted: Mon Jul 29, 2019 12:06 pm
by WayWeGo
How does the pulse counter register gallons in the tank?
Posted: Mon Jul 29, 2019 9:44 pm
by RWS
you don't NEED the pulse counter
It does, however connect to the actual meter, and gets it's data from there
So fill up your fresh water tank, reset the meter to zero, then run her bone dry = 52 gallons
Posted: Thu Aug 08, 2019 6:36 pm
by WayWeGo
So it is from the same company and designed to work with that meter? That explains it all...
