10 meter rudder bushings
Posted: Wed Apr 17, 2019 7:56 pm
by bigrgh
Does anyone know where to get rudder bushings for ten meter? Square block on bottom. Thin top hat insert and round top bushing?? I looked on Buck Algonquin site didn’t see them. Any help is appreciated. Also what’s the best way to get the bottom bolts out?? I’m 6ft3 and 300lbs I don’t see how I can get them short of pulling the deck up!!?!
Re: 10 meter rudder bushings
Posted: Wed Apr 17, 2019 8:37 pm
by 10meterman
I'm pretty sure Bob at Beacon Marine will have them and tell you how to do it.
He's always helped me
Posted: Wed Apr 17, 2019 9:25 pm
10meterman wrote: ↑Wed Apr 17, 2019 8:37 pm
X2 on Beacon
Posted: Wed Apr 17, 2019 10:08 pm
by RWS
x 3 on Beacon
Posted: Wed Apr 17, 2019 10:55 pm
by my10meter
need a small guy to fit back there. It is possible with a small guy.
Bob at Beacon has the lower ones.
I replaced my top bushings with bronze ones instead of the crummy plastic design. Problem solved. I will see if I can find out where I found them
Posted: Thu Apr 18, 2019 6:55 am
by bigrgh
Ok. I would appreciate it.
Posted: Fri Apr 19, 2019 2:29 am
by my10meter
Need someone to confirm that the 10mtr express rudder shafts i's 1 3/8". If so, this is what I installed. Clearance the hole to fit, install opposite of pic so flange sits flush and rest of bearing drops down the hole. 3 Screws and sealant to bearing flange/rudder box surface. Be sure to use a good grease to prevent corrosion . Occasionally regrease at haulout.
https://www.propellerdepot.com/00rbf138 ... ng-flanges
Posted: Fri Apr 19, 2019 7:19 am
by RWS
one of my rudders has been a bit sloppy for some time - just a bit too much play in it.
I found a sharp metal burr on the bottom of the port side rudder bracket.
This sharp metal had over the years rubbed against the bushing top, destroying it and also grinding into the top of the rudder support, making it in effect BIGGER than it should have been.
During my cosmetic refit this was addressed by filing/grinding that burr off and re-fiberglassing over the top and cutting a new hole for the replacement
- IMG_3468.JPG (48.55 KiB) Viewed 8867 times
- IMG_3467.JPG (91.03 KiB) Viewed 8867 times
- IMG_3465.JPG (69.96 KiB) Viewed 8867 times
bushing.
To prevent further wear, I added a couple of fibre washers to go between the bushing top and the bracket bottom, thereby eliminating any direct friction between the two.
Posted: Fri Apr 19, 2019 2:23 pm
by my10meter
I also had wear, thus the reason to put in the bronze ones
Posted: Fri Apr 19, 2019 9:30 pm
by RWS
wishing I had known of those
hindsight is 20/20...……..
Posted: Sat Apr 20, 2019 10:46 pm
by my10meter
Great part for Bob to carry
