Posted: Sun May 01, 2011 9:23 pm
Codger,
I used all 4 original holes in the bracket. The hole pattern straddles the groove in the bow and yes the holes are right on the top edge of the groove. If you look closely at the back of the bracket in the picture you can see this. This way the groove is kept clear. There is a backing plate on the under side of the deck with the same hole pattern which is made of marine plywood. LifeSeal was used to seal things up on both sides of the deck.
I won't be at the boat again for a few days but I can take a few pictures then if you need to see more. Let me know.
