Msd ignition
vabeach1234
Re: Msd ignition
Post by vabeach1234 »
On my 318 I installed a Hot-Spark electronic Ignition Kit.
http://www.hot-spark.com/
I also have the marine MSD marine ignition.
I originally ordered 2 different pertronix kits but they never fit my distributor. They would have required me to grind off the points stud in the distributor plate which I didn't want to do. The hot-spark kit fit without any modifications. Much more reliable now.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Re: Msd ignition
I installed a Sierra electronic ignition conversion kit in my Mallory distributor about 10 years ago and haven't had a single ignition issue since. Sure beats the maintenance of keeping the points tuned properly.
44Ydnar88
Re: Msd ignition
Post by 44Ydnar88 »
I figured out the problem midway last summer, I had a bad connection in the leads from the pick up in the distributor. It was a weird problem. Went in a few circles to get to the pick up. So the msd questions were less about throwing parts at a problem but seeing the advantage of running a CDI multi spark box, the GM HEI got a little off track but the idea was there to examine the potential. There's nothing wrong with the Mopar box, does exactly what it's designed to do, send a spark to the plug, but when Chrysler introduced electronic ignition, there were rotary phones and party lines. Even though that phone worked as designed, I would pick a smart phone. I'm just curious if a Chrysler LM318 could benefit from an updated ignition. If I had to pick I would rather know what the 8 holes above the galley sink are for,
76 F25 H/T Express
96 Baja 208 Islander
87 Baja 180 islander
Re: Msd ignition
Did you ever post photos of the 8 holes ?
Paul - SW Ontario
Re: Msd ignition
Post by Paul - SW Ontario »
Paul wrote:I installed a Sierra electronic ignition conversion kit in my Mallory distributor about 10 years ago and haven't had a single ignition issue since. Sure beats the maintenance of keeping the points tuned properly.
Hi Paul,
Not sure if I had asked you this before, but are running a 318 or 360?
And do you you know the part number to your Mallory Distributor?
My apologies if this leans towards 'hi-jacking' of a thread....
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Re: Msd ignition
Hi Paul,
Hi Paul,
I have a 350cid with the Mallory distributor. I don't have the part number handy but I can get it next time I'm out at the boat if you need it.
44Ydnar88
Re: Msd ignition
Post by 44Ydnar88 »
Mine is a mirror of this brochure,
f 25 Express 2.jpg (148.71 KiB) Viewed 7158 times
76 F25 H/T Express
Paul - SW Ontario
Re: Msd ignition
Hi Paul,
Hi Paul,
Sorry Paul, realized after I sent the post, that you are powered by GM not Chrysler.
