Posted: Wed Jul 25, 2012 11:38 am
+1ready123 wrote:Two engines one tank is still two anti siphon valves!
Call BEACON MARINE @ 609-713-4602 -- For QUICK answers to your Trojan questions
http://trojanboatsforum.net/wforum/
Ok guys this is the big weekend. Going to remove the gas line from the tank and check the valve. Kind of worried about gas spill over but I guess it wont be too much.djmair wrote:Can't swap, copper pipe. Kind of hard to get to but I am going to see if I can remove the port line.boatsnbars wrote:Can you swap the fuel lines from one pick up to the other? If you can and it is a check valve the other engine should now have the problem.
