Look I am man enough to admit I HAVE to have the 72degree air in order to sleep or I am a miserable S.O.B.! YEAH I am SPOILED TO! Why can't you admit it?alexander38 wrote:ok the wife too.....
gen-set and co
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
- alexander38
I'm perfect....
- alexander38
from un-perfect people ....see can't judge me..
- alexander38
1, you can't...prowlersfish wrote:how do I respond to that .alexander38 wrote:I'm perfect....
for your first post , sounds like good idea ,
Don't forget CO detectors to be safe .
2, thoughts on back pressure ?
3, read my 2nd post.....
The 'Judge' will have a field day with you when they read the 'copy & paste' I just did of your post! They are going to be bribed with something you can't top!!!!!............alexander38 wrote:from un-perfect people ....see can't judge me..
alexander38 wrote:1, you can't...prowlersfish wrote:how do I respond to that .alexander38 wrote:I'm perfect....
Don't forget CO detectors to be safe .![]()
3, read my 2nd post.....![]()
1) But I want to
2) many engines have under water exhaust with out issues . also put a relief hole at the 90 ( 1/4" or so ) won't make much noise and a good way to check water flow . and its a siphon break too
3) I did but its still worth saying again for others benefit too ( safety first )
- alexander38
but wasn't that a rear exit under the swim platform...? and used underway ? but that in mind I should be all right,jhalb wrote:This was talked about on the old Regal forum a couple of years ago. The guy who did it used PCV and drilled a anti-siphon hole in it. From what I recall he said it worked great.
now to figure out a ez way to install and remove it, and putting it in every anchor set no is biggy have to do poop runs at least twice a day.
as far as anti-siphon goes would I need that since I'll not be using this underway ? and the elbow will a 45..
- alexander38
good thought...prowlersfish wrote:in case of shult down or engine kicking back . It maybe running fine now but it is a boat .
You all can't take a little heat, come visit in Texas in July and August! AC just gets in the way of enjoying the heat.
Seriously I will have an AC in the Phoenix, hopefully the diesel 8K Onan will be installed so I can escape when on the hook.
- alexander38
Heat shoot , I grew up in Sabine Pass I can do the heat and raise you 100% swamp humidity,
but I did marry a Yankee and they melt...
