wood rot
No barrier epoxy for wooden hulls. The barrier coat's primary function is to reduce water penetration (ie osmosis) on fibreglass hulls with porous gelcote. Not really needed on a wood hull. Also, a wood hull will always flex a bit, so any barrier coat would likley crack open here and there as things flex. Just go with antifouling.
joanwillison
Post by joanwillison »
Thanks. So happy I found you! Appreciate all of you advice.
Joan
1967 Lady Jane, Ontario
randyp
Post by randyp »
Joan
Just emailed you concerning gutters, but here's a couple of good sources for boat building and maintenance: Jamestown Distributors (http://www.jamestowndistributors.com) and Defender Marine (http://www.defendermarine.com). IMO any penetrating epoxy should provide a temporary fix for the transom "punkiness", but eventually you'll want a more permanent (aka expensive) fix done.
I grew up with wooden boats, having spent my misguided youth on the New England coast aboard all sorts of lobster and work boats....all made of wood, and I can only say that they are nostalgic, but also money pits. When fiberglass came along my dad, and then I, jumped at it!
Nothing says "boat" like a wooden one, but they are commitments of time, money and love. Just sayin'
The folks at Beacon Marine are a great source of information, so don't hesitate to give them a call also.
Randy P
1977 F-26 HT
"Blue Heron"
No thats for a F glass boat Just use Bottom paint
That was for a fiberglass hull.
