running the Engines on the "hard"
risctaker
Post by risctaker »
Got it..thanks. When I was buying the boat, I gently turned each prop/shaft with the tranny in neutral to make sure nothing was seized up at the business end. The cutlass bearings made a screeching sound like fingernails on a chalkboard. Is that because they were not wet? or is there some issue I need to know about them?
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
risctaker wrote:The cutlass bearings made a screeching sound like fingernails on a chalkboard.
Humm - that doesn't sound good ... mots are some form of nitrile rubber, and I don't htink that shoudl "screech", and I've never heard one screech, but I haven't been under many boats on the hard turning the prop shafts, so someone else with more experience should reply.
wowzer52
Post by wowzer52 »
Dump water on it and turn it some more and see what happens. Did the shaft have play in it or was it ni9ce and tight?
1975 F-32 "SIMPLY BLESSED"
The screech is from turning dry. Doesn't happen with all but some will.
Not that abnormal
risctaker
Post by risctaker »
OK Thanks guys. I'll water them down real good then turn them again. There was no play in the shafts when I tried this. nice and screechie tight.
aka "Basket Case"
Weehawken, NJ
They also could binding do to being out of alignment because the boat is blocked up and not in the water
risctaker
Post by risctaker »
Very possible. Actually the stbd shaft alignment looks a bit out to me just by eyeballing it. Will it go back into shape after returning to the water or do I need an alignment tool while it is blocked up?
aka "Basket Case"
Weehawken, NJ
depends how it its blocked , you can get it close on land but finale adjustment in the water is the right way
Become a supporting member today
fpawn1
Post by fpawn1 »
I put a flushing valve on the raw intake hose--once done very simple to run engine the hard
ditto here
risctaker
Post by risctaker »
The flushing valve sounds like the way to go...thanks. For the immediate, I'm talking to BobCt about buying his "Fake-a-Lake"
aka "Basket Case"
Weehawken, NJ
OK< I'l bite (without using Google) ...
What is "Fake-A-Lake"?
My dog did that on the last trip to the Rockville Regatta, but I don't think that's what you were referring to.
:wink:
risctaker
Post by risctaker »
Basically a $55.00 modified toilet plunger with hose attachment built in and a long adjustable pole to place under the boat and over the raw water intake. Basically a "Fake" Lake so you can run your engines on the hard if you happen not to have hose attachments installed in your intake strainers near the engines.
aka "Basket Case"
Weehawken, NJ
Why not add a T, valve and water hose connector to your intake hose - close the scuppers and opne the T-Valve to your hose connection and it pups in. No worries of the toilet plunger coming off ...
