Learned somthing new. Its a good day.
dose any one know the answers im looking for
Huh, is that a common thing on the Chryslers? Not that I've dealt with alot of RH rotating Chev engines but I've only ever seen gear drives in the these models along with the starter mounted in the bell housing as opposed to under the engine block.
mr elevman
i called the dodge dealer that services my work truck and hears the poop lh moter has a timing gear inbetween the cam and crank rh moters have a timming chain thus disrib rotation is the samr on bolth lh and rh rotation the cam is your firring order si in a lh moter the crank and can spin oppisit of each other in a rh moter thay spin the same dir and the parts are inerchangablethis is comming from a 35 year mopar machanic
mr elevman wrote:i called the dodge dealer that services my work truck and hears the poop lh moter has a timing gear inbetween the cam and crank rh moters have a timming chain thus disrib rotation is the samr on bolth lh and rh rotation the cam is your firring order si in a lh moter the crank and can spin oppisit of each other in a rh moter thay spin the same dir and the parts are inerchangablethis is comming from a 35 year mopar machanic
they never put a reverse turn engine in a truck or car so unless your dealer just happens to mess with boats , the would not know
- ready123
As there is a gear on top of the camshaft to reverse direction for distributor drive, the reverse engine needs a spacer to lift the common distributor up as it mates with this extra gear.mr elevman wrote:you can put the same distribiter on a rh and a lh chrysler thairs no gear on the end of the shaft it mates by post and sockit but theirs a drive gear the drives the oil pump and dist.
- guglielmo6160
