Propane tank question....
Propane is common on sailboats . All the sailboats I have seen that use propane have a locker for the tanks . the locker is set up so if the tank leaks the propane will vent out side the hull ( vents at the bottom of the locker) . Propane is heavier then air and can settle in the bottom of the hull .
There have been boats blown up due to propane , so you need to be careful and do it right. And yes you can say the same for gasoline .
Myself ? I would not have it or candles for that matter :wink: smoking ? back deck at 20+ knots only
abkeywest
Post by abkeywest »
My 83 Carver Mariner came from the factory with the optional propane 3 burner stove and oven. The tank is in a locker mounted on the swim platform. There is a control panel near the stove with a switch to turn on the gas by way of a solenoid mounted on the tank. Works very nice.
1983 33' Carver Mariner
abkeywest
Post by abkeywest »
abkeywest
Post by abkeywest »
abkeywest
Post by abkeywest »
abkeywest
Post by abkeywest »
abkeywest
Post by abkeywest »
abkeywest wrote:...The tank is in a locker mounted on the swim platform....
Best place to put a tank IMO. It's low and overboard.
abkeywest
Post by abkeywest »
Not sure why so many replies. Sorry
I think we're having a problem with the server. There have been a pew dup posts in the last couple of days.
DOUGNASH
Post by DOUGNASH »
I use a standard 20lb propane tank, it sits where the refrig would go in the wet bar in the cockpit.
I never had a problem and always shut it off at the tank when done.
I just use it for bbq.
My plans where to rebuild the wetbar with a tank locker below the sink of the wetbar.
For me those little 1lb disposable tanks made BBQing a big headache when cooking lots of stuff.
DOUGNASH
Post by DOUGNASH »
DOUGNASH
Post by DOUGNASH »
duplicate post
sorry
